co-polarization and cross-polarization
sanders
Member level 3
what is co polarization
What is co-polarization and cross-polarization ? What features they can specify for antennas ? Is it related to "radiation pattern" ?
At the antenna connector you may receive (or transmit) only one wave polarization. (linaer or circular). The 90° far polarizzation is generally unwanted.
Cross-polarizzation (Xpol) is the 90° far, unwanted polarizzation.
Co-polar (Copol) is the wanted polarization.
I.e. if a standard antenna TX a vertical pol. , in far field region, when you RX a Vertical one, you RX the Copol, while if you try to receive Horrizontal, you'll receive the Xpol.
Many definitions exists for Xpol. For my knowledge, the most widely adopted is the Ludwing's one.
A good antenna has Xpol less than -30dB
