Apr 21, 2012 #1 B bhathi123 Newbie level 5 Joined Feb 5, 2012 Messages 10 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,384 What is the relationship between CNR and the modulation scheme used?
Apr 21, 2012 #2 ChakerQ Member level 1 Joined Mar 30, 2012 Messages 40 Helped 18 Reputation 36 Reaction score 18 Trophy points 1,288 Location Tunisia Activity points 1,503 Hi, If you mean by CNR : Carrier to noise ration, we have this relation : Eb/No = CNR * W/B with B is baudrate and W is the bandwidth Using the same baudrate B, the bandwidth change with modulation scheme. If your question is not about this, please explain more. Regads, Chaker
Apr 22, 2012 #3 B bhathi123 Newbie level 5 Joined Feb 5, 2012 Messages 10 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,384 Thankx ChekerQ... CNR= Carrier to Nosie ratio, If the required bit rate is given, then baud rate will change with the modulation scheme. How can I calculate the required bandwidth?
Apr 22, 2012 #4 ChakerQ Member level 1 Joined Mar 30, 2012 Messages 40 Helped 18 Reputation 36 Reaction score 18 Trophy points 1,288 Location Tunisia Activity points 1,503 Hi, First you can see this article. It can help you http://sss-mag.com/ebn0.html About bandwidth there is different definition. In many cases we use the filter badwidth or canal bandwidth but in digital communication books we define bandwidth by other definitions. The famous one is null-to-null badwidth. This bandwidth depends on modulation schema : Take a look to the book : Digital modulation techniques : Fuqin xiong Regards Chaker
