erikwikt
Junior Member level 1
- Joined
- Nov 21, 2010
- Messages
- 18
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,445
Sure; that's fine!... Can I simplify it to 3/2? So that I get strait lambdas?
The actual silicon mobility ratio µn/µp ≈ 2.7 , hence a factor of 2.5 or 3 comes closer to reality.To my second question, I have read from other sources that a rule of thumb is that the with of the PMOS should be twice the with of the NMOS because of the mobility in the material.
3 times :?: 3/2=1.5 :!:... the minimum length of the gate for both the NMOS and the PMOS, which is 2 lambda.
So if the width of the PMOS gate has to be 3 times larger then the length, ...
No: (2 * 3 * 1.5) = 9λ .... will the total gate with be [(minimum length) * (the mobility rule) * (the with ratio)] = (2 * 2 * 3) = 12 lambda?
The size ratio for the NMOS transistor should be 3/2 and 3 (3/1) for the PMOS.
So wont the with for the PMOS be equal to 2 * 3 * 3 = 18 and 2 * (3/2) = 3 (or 6 if i chose the length for the NMOS gate to be 4)?
Just keep the old PMOS/NMOS ratio. If you want to consider the µn/µp ratio (which is about 4.7 for 180nm CMOS), you could adjust the PMOS(W/L) / NMOS(W/L) ratio for this factor.
How can I adjust the PMOS(W/L) / NMOS(W/L) ratio by considering the µn/µp ratio?
As the mobility ratio for 180nm CMOS bulk processes is about 4.7 (s. the image below), the PMOS(W/L) ratio should be this factor greater than the NMOS(W/L) ratio, if you want the same drive strength from both transistors. So if you selected W/L=540nm/180nm for your PMOS, your NMOS needs only a W/L=115nm/180nm. For more info see e.g. the book named at the image below.
... David Binkely's book. The values for carrier mobility are strange. Both UMC 0.18u and TSMC 0.18u have a carrier mobilty ratio of approx 2.6, not 4.7 as in Binkley's table.
Irish or Scottish, Hans? ;-)Slainte!
H
Strange, yes. May be an anomaly of his special process? Rather bad PMOSFETs?
Our 0.18 processes (from 2 other foundries) also showed µ ratios in the vicinity of 2.3 .. 2.5 .
