gmahajan027
Junior Member level 1
I was studying about the subthreshold region operation of a CMOS inverter
If I have a device of threshold voltage of NMOS =0.2volts , and I want to make a CMOS inverter with it that can operate in sub-threshold region.
plz suggest the vdd for the circuit I should use
I already used a Vdd of .150volts but could not get correct results.
Also what should be the magnitude of capacitance at output i tried using 1ff and 1e-4ff but no good results.
I will be thankful for any help..
