cmos 3mA current mirror by using pmos-transistors
p.sivakumar
Member level 1
Member level 1
Hi every body
this is sivakumar from GDA Technologies ltd .I am working as analog designer.Now I am designing pmos current mirror ,So I need some help from analog designers that is ,is it possible to design 3mA (huge) current mirror by using p-mos transistors.If any one knows regarding current mirror.I hope that you
will be helpfull to me.
Thanks &regarding
P.sivakumar
p.sivakumar@gdatech.co.in
Bangalore
India
Mobil number 09886440705.\]
it is OK to design 3mA current mirror by using pmos.
because the current is a little high, choose the suitable w/l of the transistors. also, check the number of contact, width of metal for current density.
BTW, are the transistors connected to PAD? if yes, follow the ESD rule.
In this case I think using BJT is better than CMOS
Else try BiCMOS
PMOS current mirror with load current 3mA is OK. But the point is what is this current for! You better concern about this more than using bipolar or CMOS current mirror.
you can shut many mos transisters.only one is bad design
PMOS can handle 3mA of current, but fingering is highly desired in the layout to alleviate realibility issues. Hope this helps.
Rgds
