circuit
Full Member level 2
clock termination
I am designing a board which takes in a external clock through a SMA connector, Now I was wondering what should be the width of the clock trace (10mils) ? and what should be the termination on the the signal ? The clock frequency will be a max of about 19 Mhz.
I am attatching the circuit where I need to route the input clock to two different chips...What should be the R, C values and what if there is just one clock I am going to route directly to the chip ( should I choose 50 ohms in this case ?) Thanks much. Where should the R be placed ?
