Clock recovery problem with FSK demodulator
Vonn
Full Member level 4
Full Member level 4
Clock recovery ?
I have built an FPGA-based FSK demodulator but i have a problem in clock recovery ... can any body give me a hand in this prob. Thanx
I just know some about clock recovery from NRZ or RZ format data. There are useing some dpll skill in the process.
one method
In the analog world a method that is within 1 dB of optimum is
1. Slice the base band data signal to get hard limiting
2. Low pass with a 1 pole filter at 3/8 of the bit rate
3. Square (full wave rectification will also work but is a few dB worse
4. Filter out the spectal line at the bit rate
Can this be approximated in your FPGA?
Can you design the signal format for easier clock recovery (at the expense of wider signal bandwidth)? For instance, a return to zero scheme with the frequency shifted up or down from the center represents a one or zero and comes back to the center for a short time to make the return to zero part. That way you can slice the signal up and down and know that you have the bit period completely determined.
i don't know why specialy 3/8 of the bit rate in step 2 ? but any way .. to do it digitally i think it's more easy than what u say ... just i don't know how ?!!
clock recovery
Can you explain your problem in more details. I had do some effort in my thesis. :idea:
geni answer
To answer the question by Geni, The one pole low pass filter -3 dB frequency in Hertz is equal numerically to the bit rate multiplied by the fraction 3/8. This method is mentioned in the about 20 year old satellite communications book by Spilker.
You can get some information in the attached docs.
good luck
chwpark
yeah, i get some good idea from this reference
ok but ...
it's ok this pdf gives a good solution in orthogonal frequencis
but in my case ...
to be more clear
1- i am receiving BFSK
2- buad rate 1200 Hz
3- F1=1300Hz for "1" , F2=2100Hz for "0"
4- pilot stream = 01010101010...
now how can i get the true 1200 Hz from the incoming stream ! :cry:
