Clock Enabling and Clock Gating
AdvaRes
At home
Hi members,
In my reading I find this two terms:
Clock Enabling
Clock Gating
Is it the same technique or there are differences ?
They are not the same. Use clock enables in FPGAs and clock gating in ASICs.
Reactions: pkuzz
    pkuzz
Could someone elaborates what are the difference as well as the similarities ?
Which is better ?
clock gating is for DFT design and clock enable is just mean the clock will be enabled!
Hi friend
Can u be more clear in ur answer
I'm talking low power techniques.
Guys, please do not confuse.
These are referring to the same...
To disable (switch off) the clock to a register, a clock gating cell is used...
To enable/disable this clock, clock enable will be used in clock gating cell...
So, both are same...
For simplicity, take an AND gate as clock gating cell; one input is clock enable and another input is clk. Now controlling the clock enable, can enable/disable clock to the register.
This technique is used to save clock power in the design, as it is 40-60% of overall chip power
Not if you are working with FPGAs. Using FFs with CE pins is fine, gating the clock manually with an AND gate is in most cases not.
