mrwest3r
Newbie level 3
Hi there! As my entrance to the world of electronics, i decided to buy a DIY-kit off of ebay. This is the first time i ever assemble a curcuit-board, and also the first time i solder something. I followed the schematics very carefully. Although this is the first time i solder on a board, i think the results came out good. While in the procedure, i checked that the right pins were placed correctly.
The only problem i have is that it wont work. I have tried with the following voltages: 9v, 6v, 5v. Have anyone put together a kit like this before? It came to mind that i had maby soldered the leds with oposite pins, but i tested the leds with low voltages, and they are correct.
See the pictures attached for the finished work.
Thank you in advance!
