cupoftea
Advanced Member level 6
Supposing you have a 24V, 20W, 90-265 , isolated Flyback on a PCB whose edges are enclosed right up against an earthed metal enclosure.
What distance to the edge of the PCB is the primary side copper allowed to go to?
Is there any trick (to reduce distance) like having kapton tape simply stuck to the enclosure where the PCB edges touch up against it?
Also, i assume the isolated secondary side copper has just <1mm clearance requirement from the earthed enclosure, since its isolated?
