Classic text clock - do it yourself
It is a text clock, which electronics was made on basis of:
Zegar Tekstowy | Mirley - Elektronika i Programowanie
Differences from original project are the diodes and minor things.
Assumption was that the clock function on a desk, so the size is small. A frame is the housing. Character table is a sticker worked on the plotter. Accurate separation of the luminous flux from neighbouring phrases was most problematic. Plastic channel section adequately treated and super glue were used to make that. Fitting one side of the board (the one with diodes) to the holes also was not easy to make. Forms are not very simple, but they fulfill their task as a characters separator. Highlighting is green – it was made with light green diode with personally truncated tip in order to improve dispersion.
Power supply is the charger for mobile phones.
Link to original thread – Zegar tekstowy klasyczny
