gbugh
Member level 5
- Joined
- Mar 15, 2013
- Messages
- 81
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Fort Worth, Texas
- Activity points
- 2,234
In order for a Class E RF PA to have a linear or even near linear output, must it always have an envelope EER circuit driving the supply voltage also?
I mean, if I don't do that then I'm basically broadcasting only the phase changes in the signal and not the amplitude changes, right?
If I try to drive the MOSFET with the lower amplitude portions of the modulated RF input then wouldn't the MOSFET conduct less, shut OFF sooner and then when the capacitance across the Drain finishes discharging, the output waveform would swing negative before the MOSFET gets turned ON again on the next cycle?
Do some people do it like that?
I've heard you can detect SSB from phase changes only so I'm wondering if people are using Class E RF PAs without any supply voltage modulation and it still works anyway because they are broadcasting mainly the phase changes?
Or do most people modulate the supply voltage?
I see a lot of information about modulating the supply voltage for AM transmissions but not for SSB.
Why is that?
Thanks if someone can enlighten me, George
Why is that?
