Class E Power Amplifier
khouly
Advanced Member level 5
EGYPT
i want to design class E power Amlifier for 900 Mhz application , and i want to know where to start ,
so please recommend a book , or paper to begin with
and i saw most of the class E amps use LDMOS or CMOS , or HBT , what about biploar devices are they used in this class
and also i want to ask how to select the bias point of the gate or the base
thanks in advance
khouly
Search for Sokal and/or Raab. They wrote the book Solid State Radio Engineering and they are big in Class E.
for instance:
h**p://www.avtechpulse.com/papers/classe/
    khouly
you can use bipolar decices.
But FETs are more useful for switch-mode devices.
Bipolar devices go to deep saturation, it will make slower they operation.
    khouly
i have seen class E amps based on LDMOS devices , i will try to get a model of one , and begin to design using the LDMOS
khouly
what about the base bias of the transistor if i use Bjt will be like class AB or just put the input wave form in the base
khouly
The latter case: no any bias as much as a Class AB bias, only just a little (say 0.2-0.3V DC, definitely not causing any collector current) to easy the RF drive at 900MHz, this helps the obviously not so rapid rise time of the drive pulse.
    khouly
