Clarification about IIP3 measurement in ADS
hari_preetha
Full Member level 2
Full Member level 2
Dear Sir,
I designed low noise amplifier at 1.4 GHz using Avago ATF54143 transistor. I obtained gain of S21 of 17.718dB at 1.4 GHz. Using the template of HB2 power swept in ADS, I have simulated source power, fundamental power, and third order power and using these values , I have drawn Pin v/s Pout graph. I have got the IIP3= 49.866dBm , and OIP3 = 66.138 dBm.
In data sheet of Avago ATF54143 at f = 2GHz min= 33dBm, typ= 36.2dBm, similarly f=900MHz, typ= 35.5 dBm.
I am confused with obtained values of IIP3=49.866dBm,and OIP3=66.138, Gain obtained (S21)= 17.718dB.
My question is, how to cross verify these obtained values IIP3 and OIP3 values correct or not.For 1.4GHz using ATF54143 transistor , what must be the maximum IIP3 and OIP3, we can get.Is there any formula for cross verifying these obtained values of IIP3 and OIP3 correct or not.If it is not correct , using ATF54143 transistor how much maximum IIP3 and OIP3 we must get
Some other LNA designed and tuned at some other frequency 915MHz, I have obtained the IIP3 =51dBm and OIP3=69.60dBm,gain(S21)=25dB. I have doubt on these values of IIP3 and OIP3, because I am getting the huge values of IIP3 and OIP3.
How to cross verify these values of IIP3 and OIP3 weather it is correct or not, can you clarify it. Related files of IIP3 and OIP3, I attached it.
  • ATF54143_avago_PHEMT.pdf
Dear Sir,
Someone can clarify it the above points in posting #1.
Dear Sir,
Someone can give the closer answer to the posting #1 points
When OIP3 simulation is done, max. output power for each carrier should be 20dB lower-at least- than P1dB Output Power hence xIP3 equation is still valid.
For instance...
Let's say an amplifer G=20dB and P1dB=30dBm
Maximum allowable input signal(s) for OIP3 simulation will be
P1dB-20=>10dBm-Gain=-10dBm for each.
Otherwise Intercept Point will not be valid anymore..
For instance...
BigBoss Sir,
Infact, I didn't clear, what you conveyed in the previous posting. What about Input Intercept Point (IIP3), what will be maximum IIP3, we can have. If we know Gain earlier. How to calculate IIP3 theoretically and practically,what must be the maximum IIP3.
BigBoss Sir,
Simple..
IIP3=OIP3-Gain
Since OIP3 can be measured or simulated and the Gain is already known, IIP3 can be extracted from these two by considering the conditions mentioned before..
If you use the HB2ToneSwptPwr schematic template (Insert > Template...) to set up a Harmonic Balance simulation of your LNA then the results generated include All the typical measurements like gain compression, IIP3 (also OIP3, IIP5 and OIP5) and much more.
