clamping circuit... plzzz help
rvnd5d
clamping circuit
hi all,
I want to design a clamping sort of circuit which would produce an output of 0V when the i/p to it is +5V and 5V when the input to it is 0V... the input is not a pure sine wave... its a sine-wavish pattern with a frequency of around 50-60hz...
can someone please suggest me a circuit.. plzzzzz....
thanks in advance...
Added after 1 hours 11 minutes:
hiii all... just to give you some more details about the circuit.. here it is.. the circit that I want to modify is an o/p stage(last stage) of the whole circuit I have..
the whole circuit consists of a vtg follower, the o/p of which is connected to RC filter and then to an instrumentation amp... However, the instrumentation amp produces an o/p of 5V when the i/p to the vtg follower is 0V... I want to design the o/p stage such that the o/p is 0V when the i/p is 0v and the o/p is 5V when the i/p is around 100 mV..
the i/p to vtg follower is a noise pattern which has a max magnitude of 130mV...
i want to amplify this signal so that I can send it to micro-controller circuit...
Can someone please help me.....:cry:
clamping ckts
I think that a high gain inverting amplifier or a high gain inverter can do this task for you.
clamping circuits
hii.. i did try tat.. did not work...
any prob with my ckt development??
