Circular RS-232 connector
ArticCynda
Advanced Member level 1
Hi all,
I need to find/improvise an adapter cable for the serial output of an instrument.
Documentation only mentions it's a LEMO connector, picture attached, but no part number for a mating connector is mentioned.
And as we all know, there are a quadrillion different LEMO connectors... Don't know where to start searching.
It's a 6-pole panel mounted female connector, so looking for a 6-pole male jack.
Does anyone happen to recognise this connector series?
Many thanks in advance,
AC
There are many, but not so many Lemo connectors. You need to identify the size, e.g. outer and inner diameter of the socket flange. I expect series 1E (20 mm) or 2E (25 mm) outer diameter.
