soaringeagle
Junior Member level 3
Hi ,
I am designing circular slot antenna ( fr = 475 MHz) on a cube of size 10cm(length) by 10cm (width) by 30 cm (height) cube. My square slot 'wraps around' the cube. I have also a parasitic slot at a distance of 170 cm from the first slot. I want to create the CP using this slot antenna. What is the best way to generate the CP using this design. I want to keep the design as simple as possible. I have excited the two adjacent sides of my slot antenna with two feedlines that are of magnitude 1 and 1<90degree. I am getting very nice CP using these two separate feedlines. But practically I will have to use power divider to make it work . I want to use some technique using striplines that has only one port and that may excite CP in this square slot antenna.
I will appreciate the quick response. Thanks.
