doncarlosalbatros
Full Member level 2
Circuit suggestion for an current limited power supply application
I need to make a 5V 20mA current limited for use with 10kOhm and 20kOhm potentiometer-type devices. Because of the potentiometer low resistance at the ends of its ends, if I use an unlimited power supply, and even I set it as low as a few volts, it can destroy the pot due to heating of the element.
Since the pot can go as low as a few Ohm, for a good linearity I would like to have a low output impedance as well.
So the potentiometer should be supplied by around 5V but the current should not exceed 20mA.
What type of circuit I should begin with?
The problem is when the wiper passes through a and b it damages the device. What kind of interface between the 5V supply and the pot would limit the current to 20mA?
