Circuit simulation using hfss
kryon
Junior Member level 1
I desperately need to simulate this circuit using possible Hfss.
You know that circuit simulation and EM layout analysis are completely different topics and require different tools?
Yes but I have no idea how to use hfss.some one did it and generated a graph.Heres the Image and the possible results.
The effective harmonic suppressions are further verified by circuit simulations with realistic physical device and inductor
cross-over layout mismatches calculated through HFSS simulations based on foundry-provided process parameters. Fig. 7 shows the post-simulated output power with a 50 load by estimating overall phase mismatch of 0.6 . It confirms that all undesired harmonics are substantially suppressed by at least 25 dB, while the fourth harmonic is boosted by 10.4 dB. This result is consistent with the above analysis.
Use either ADS or Microwave office.
Reactions: kryon
    kryon
