tommydidi
Member level 1
circuit question
Hey Guys,
I am going to design a circuit which should be able to achieve the following function:
If the voltage applied to this circuit is negative, exactly the same negative voltage should be sent to the output; If the voltage applied to the circuit is positive, zero voltage should be delivered instead.
Any thoughts?
Thanks
Hey Guys,
Any thoughts?
Thanks
