gauravkothari23
Advanced Member level 2
Hi all...
i want to interface 16X2 Character LCD with microcontroller, and some other peripherals, and will be operated using 4 x AA battery.
My problem is when the battery is full and voltage around 6.4V the brightness of LCD is also good and very bright and contents can be viewed very easily, but as the battery starts draining and voltage level reaches 4V the brightness gets completely dull, so again i have to adjust the brightness from brightness pin of LCD, which is not reliable in my case. so i need the solution where i can clearly view the LCD in all voltage conditions.
