Circuit for converting 110Vdc to 24Vdc
smb
Member level 2
Member level 2
Is there any simple and small circuit which I can convert 110Vdc to 24Vdc(50mA)?
convert 110vdc to 24vdc
If you need it to be safe you have to use a transformer.
EDIT: This is wrong because Smb asked about 110V DC. Sorry. I saw 110V and thought about mains electricty. Well caught hr_rezaee and sinip.
resistor for 110/24vdc
Hi smb,
The simplest way to do this is by using a TL783C, it's a circuit similar
to a LM317. But it will run hot like hell, therefore you should bolt the
TL738C to a heatsink and connect it to the 110V through a 1k/5W resistor.
Regards,
on1aag.
from 24v dc to 110v
hi
dc to dc conversion and transformer !!!!
regards
110vdc to 12vdc converter
You can't use transformer for DC. It is for AC only!!!
110v dc
if u dont want to use LM just check current requirement of ur object which is to b drawn with 24V and then use a combination of resistances to block required voltage
ig resistors r getting burnt use high power i.e. normal resistors r 1/4 watt
u use 2 watt
convertisseur continu-continu (110 vdc-24vdc)
u use 2 watt
You can do that only if very small curent is needed. Look, voltage difference is 86V and if the current is only 0.1A the resistor needed is more than 8W!!! So resistor solution is probably out of question, and it will disipate too much heat anyway.
110v to 24v dc
Hi
May be a AC-DC IC should be better!
Regards
110 vdc
it is mentioned in first post that current requirement is 50mA then why to go for big circuity
conversor 110vdc 24vdc
But it still makes 4W dissipation. OK, so if the current is constantly 50mA you can put resistor (calculation of its value is quite simple) and 1W 24V zener diode to stabilise it and then feed whatewer device you need to be at 24V. But remember resistor must be 4W or more! And don't touch it or have some flamamble material nearby.
110v dc to 24vdc
dissipation how.......?
if accross resistor then it is
(110-24)x50m=4.3W
then u will need 5W resistor (i dont know it is available or not)
and it makes 1.72 KΩ Value
so u should use some series parallel combination to make exactly 1.72KΩ
110/24 dc converter
Dear,
Check phoenixcontact Site and MINI-PS Series Power Supplies.
www.phoenixcontact.com
Very good quality and works with both ac & dc inputs.
Good Luck!
110vdc/24vdc
(110-24)x50m=4.3W
And what did I say? When I say dissipation I mean heat dissipation. There will be 4 W turned into heat so it will run quite hot.
110vdc to 24vdc converters
use a dc-dc converter as Buck
convertisseur 110vdc /24vdc
its the thing friend is asking us to give a circuit for that
110vdc zener diode
Dear,
use a miniature DC/DC Converter.
I attached a Example Datasheet from TracoPower THP3 that convert 36~180V DC
input range to -12/+12V 125ma . you can use it as a 24 V Converter.
another example: check this link,C&D TECHNOLOGIES DC/DC Converter Selection guide
http://www.cd4power.com/data/power/cd-dcdc_pdb1.pdf
also take a look at XP POWER Site,they have nice products.
http://www.xppower.com
Good Luck
110 v dc to 24 v dc
hi
I finished 110vDC to 12Vdc &2A by LM3524 .It is work so good.
110vdc 24vdc dc dc converters circuits
wht actually LM means.........???
Added after 5 minutes:
my diode gets blown every time i use.......i hav used TIP31C instead of 2SC1062
NPN SILICON TRANSISTOR.......is this causing the diode to blow off or ny wrong
specification in d circuit........
help me out in knowing d problem in my circuit
convert 110 vdc
for 50mA out put ,you can use a resistor & zener diod.
Added after 4 minutes:
for 110vdc to 12vdc ,the best choice is a computer power suplly.
Reactions: magz
    magz
using the tl783c
Hai narsimha0350
As per the given schematic, nothing seems wrong and the zener diode shoudnt blow off. If it does, may be the transistor is short. Please check. Goodluck
