bongkk
Member level 1
I have had a lot of burnt Mosfets while prototyping an inverter. If found that the culprit was the drive. I read elsewhere in this forum to use an LM324 opamp (thanks to him or her). Sure enough it solved my problem. Having tried many other op-amps, i found that only Lm324 works best (at lest at 50/ 60Hz)
Attached is my generic circuit diagram to share with you all.
