circuit diagram check in the respective links
rajaram04
Advanced Member level 3
earth
Hello sir
Please check the circuit diagrams in the links here
Are akk ok or not ? which one is good ?
**broken link removed** is probably the most simple
Ok thanks :) here the input voltage is given 17-30 volts , so is it compulsary to apply 17 volts in minimum ?
& what if i use to make a total of 12 volts 1 Ah from 3 single battries of each 4 volts 1 Ah (in series) ??? Is it compact woth the circuit ??
17V is the min
4V lead-acid batteries?
IF the batteries are in good condition and about the same charge state it should be ok.
Sir , what changes we need in component's value if we apply same circuit for
!) 4 volts
2) 8 volts
please explain it for both ! thanks
