crazydave2002
Newbie level 3
I am currently building an active noise cancelling headphone. However, there are some circuit design problems that I am not sure on my design.
Basically, in my design, there is a mic capsule connecting a low pass filter pre-amp.Then the pre-amp is connecting to inverter, which can generate the inverted frequency. However, I don't know which circuit should I build to connect the mic capsule to the pre-amp.
Actually I am some more questions. If you are pleased to answer the questions would you mind leave your email/ message me via this forum. Thank you.
