[SOLVED] Circuit design optocoupler 4N25
masoud1234
Junior Member level 2
I'm designing a circuit with optocoupler 4N25 and 24v dc input which output is connected to the microcontroller
Please calculate the resistance
R1=?
R2=?
R1 = 450 ohm. It is designed to work for 5 volt. Resistance should be more than 450 and upto 1200.
R2 = 1k ohm or higher. (I guess)
thanks
Calculated :
KVL: -24+(R1 *I1)=0
R1=2.4 KΩ It is true؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟
Please calculate R2
R2 is 10k as mentioned by tpetar. It is a pull down resistor and are used in a range of 1k to 10k.
Hello masoud1234,
for R1 you have to calculate like this:
VF = 1,2V ; IF = 10 mA
R1 = (24V - VF) / IF = (24V - 1,2V) / 10mA = 2200Ω = 2K2
Calculate for R2:
R2 = (5V - VCE(SAT) / IC
From Datasheet: VCE(Sat) = 0,3V
IC = 1mA
Regards
Rainer
R2 = (5V - 0,3V) / 1mA = 4700Ω = 4K7
    Mattooc
