"is everything ok in it ?"
Is this a serious question?
What is the purpose of the circuit?
It's not O.K. to pullup the TSOP1738 output to 12v (or about 10V). I stopped thinking about the circuit at this point.
The 12V supply voltage is too high for the TSOP IR receiver (6V maximum) and also for the CD4017 in that circuit. Circuit designs from that website have not used datasheet information and simple arithmetic to select supply voltages and component values.
The CD4017 has an output that drives a high current in the LED so its output transistor will become too hot when the supply is 12V.
Two more outputs on the CD4017 drive high currents into the 1k transistor base resistors and these outputs on the CD4017 will also become too hot.
If the supply is 5V or 6V then everything will be fine if the relays have a low current 5V or 6V coil.
What will an amplifier and a power transistor be used for?
Simply use a 5V or 6V regulator for most of the circuit and have the relays and their diodes connected to +12V like they are now.
You forgot to tell us the resistance of your relay coils so we do not know how much drive they need.
Why don't you look on their datasheets like we do?i am removing relay system totally & applying the of 4017 as per my use
is it possible to drive IR sensor , 555 & 4017 with a 9volts duracell ??
The maximum supply voltage for the TSOP is 6V but they recommend 5V.
The output high voltage of the TSOP will not be high enough.
