JFParnell
Newbie level 3
I am a mechanical engineer that is responsible for also producing PCB drawings for manufacture. We send these drawings out with a set of gerber files to the manufacturing houses to specify what we need from our designs. Recently we have been trying to greatly improve what we specify on our drawings, as we have realized that what we were calling out was insufficient. With that being said, we are currently very wrapped up in specifying final copper trace thicknesses for our stackups. We are trying to avoid getting too much thickness as this makes SMT rework very difficult due to the large copper thickness heat sinking away the the heat and not allowing the solder to flow. We have one current design that uses two different circuit boards and stackups and are trying to specify the final copper thicknesses of each layer.
1) Stackup is a six layer board, with .062 final thickness. The board is to be IPC Class 3, which specifies a minimum plated thickness of .000787 in the vias. Layer 1 (top trace layer) is .0007 copper foil bonded with prepreg to layer2. Layer 2 and 3 are .0014 foil bonded to a core. Layer 3 is bonded to layer 4 with prepreg. Layer 4 and 5 are .0014 foil bonded to a core. Layer 5 is bonded to Layer 6 (bottom trace layer) with prepreg. Layer 6 (bottom trace layer) is .0007 thick copper foil. Vias are plated .008 diameter thru holes through all layers. The question then is what are the final layer thicknesses that are possible for each layer? I assume that all of the inner layers for this layup will be very close to the original .0014 thickness as they are not plated, but they will be slightly thinner due to the action of the press. Thus the major question is what thickness of the outer two layers will be when the plated vias get to .000787 at the center of the board.
2) Stack up is a four layer board, with .062 final thickness. The board is to be IPC Class 3, which specifies a minimum plated thickness of .000787 in the vias. Layer 1 and 2 are .00014 thick foil bonded to a .021 thick core. Layer 2 is bonded to Layer 3 with prepreg. Layer 3 and 4 are .0007 thick foil bonded to a .021 thick core. There are blind vias through layer 3 and 4 of .008 diameter, and thru hole vias through the whole board of .008 diameter. I would like to know again what are the possible copper trace thicknesses of each layer when the middle of the vias get to .000787 minimum thickness.
The electrical engineer is trying to achieve .0014 final nominal copper thickness on all of the layers, but I am not sure this is possible, especially after viewing the inspection reports on the prototype boards. We are currently seeing final thicknesses on layers up in the .00488 thick range, which is huge.
Any help with understanding what is achievable with current technology would be greatly appreciated.
JFP
JFP
