Chosing SMPS controller ic
baby_1
Advanced Member level 1
Hello
i want to create a small SMPS as soon as possible.i rectifier my voltage and set up an EMI filter.my output voltage is now 315volt.now i want to have 15V/4A output.what ic should i choose? could you introduce me some of them?
Thanks
Hello and thanks tpetar
is another ic or circuit that have one mosfet switch transistor instead of push-poll structure?
For a 60W power output you may consider the FlyBack design.
The Flyback SMPS theory and some design calculations details here:
You may use:
1. standard UC 3842 In flyback mode with a mosfet rating of 800-900 volts
One example of SMPS here:
http://www.smps.us/12volt-powersupply.html
This can be modified to 15V by changing R15 to 12k, R14 = 2.4k, also need to change D6 (by a 16V zener diode)
2. the Power Integrations ‘TOPSwitch’ family are compact solutions, check the appnote for discrete SMPS described step by step.
3. the Viper from ST, you may find also The VIPer Switch Mode Power Supply Design Software
4. A very good free Switch Mode Power Supply Circuit Design Software /Transformer Calculation / Simulation Tool you may find here:
http://www.poweresim.com
Reactions: baby_1
    baby_1
Dear baby_1
Hi
It is pretty simple ! at first you should determine that what topology you are deciding to use ! and then you can find your desired controller .
Is isolation important for you ?
Best Wishes
Goldsmith
Hello Goldsmith
i has been choose my SMPS controller ic(UC3842)
Thanks
@Goldsmith
As long as you have reopen this discussion, what’s in your opinion the best SMPS topology to obtain about 60W?
And by the way, a tipical SMPS have an key role in providing safety isolation between the input and output, so one important idea behind designing a switch mode power supply is to incorporate line isolation using a transformer.
:cool:
Dear mister_rf
Hi my friend
How are you ?
For 60w , my suggestion is a simple flyback converter . but if isolation wasn't require , i would suggest a simple buck.
Best Regards
Goldsmith
If let me design a 15V/4A SMPS, I’ll consider to use quasi resonant PWM controller-NCP1207A/B.
Because the QR mode Fly-back converter has low EMI noise.
Reactions: baby_1
    baby_1
I don’t think the EMI is a main concern here. For a beginner project it’s important to have access to the components and a clear model to follow. The 3842 series are a very popular model, lots of info on the net, low cost and ready available on almost every electronic shop. :smile:
