garimella
Full Member level 5
I have to develop a power meter that will record harmonics on incoming 3 phase currents and display the power quality such as THD to the user. Now I am not sure how to select CT for my application as primary CT on the power lines are sensitive to 50-60Hz . Since I need to measure upto 9th harmonics, should I choose CT with higher frequency response? Will the primary CT not attenuate higher order harmonics?
Just to clarify: Primary CT is 1: 100/50Hz-60Hz, Nominal is 500A . The output Nominal current is 5A. This current will form the input to my meter.
