Obviously, the input (mains) side must be the same at 230V.
The output is DC 14.5V which you want to match as close as possible but as long as the current rating is not less than 530mA, any adapter will do. The current rating tells you the maximum you can draw from the adapter so if you use one with a higher current rating it just means a bigger safety margin.
Brian.
