mw_rookie
Member level 2
Hello,
I am looking for RF absorber shields for my PCB and have come across:
RF Absorber Shields
For a clearer understanding, if my board is operating at say 600 MHz-800 MHz, can I use PS800EMC24 from the catalog? It's peak attenuation is at 800 MHz, so, it should absorb any radiated emissions up to 800 MHz. But my operating frequency falls within the absorber frequency range. I will be using a microstrip/CPWG line on the board. So in any scenario will my required frequency see any attenuation?
Also, when I select an absorber sheet for the PCB, then the return loss of the sheet for my frequency has to be low. In case it is about 2 or 3 dB only, most of the radiation will be a reflected/heat loss. In that case, the shield is not serving any purpose. Is this understanding correct?
Any info on the above is greatly appreciated.
Thank you for interest and help.
RF Absorber Shields
