ElectroPhilip
Newbie level 1
Dear all,
First of all, hi I'm Philip and nice to meet you all
I'm a designengineering student from Delft.
My question is farily simple, I'm looking to make a dimmable high power LED setup.
The LED chould be dimmable by using the PWM signal from the arduino.
Something like this;
I want the driver to be a constant power supply, with some sort of transistor to act as a gate.
This gate should be PWM controlled by the Arduino to give it a illusion of dimming (where in fact it's the duty cycle variation).
I've done similar setups before with simple low-power LED's, but I'm not sure on picking a transistor for this setup, in which a lot of current will flow through the transistor.
Thanks for your time!
Cheers,
Philip
Cheers,
Philip
