Try to find siglib, loads of dsp source code, might have what you are looking for.
SigLib sample
File Name : CHIRPZ.C | Author : JOHN EDWARDS
Siglib Library version : 6.00 | Modifications :
Compiler : Independent | Start Date : 16/07/94
Options : | Latest Update : 02/06/01
Support for SigLib is available via Email : support@numerix-dsp.com
This file may be modified, in any way, providing that this header remains
within the file and the only additions are made to this header.
THIS FILE MAY ONLY BE USED IN ACCORDANCE WITH THE TERMS OF THE NUMERIX LTD.
END USER LICENSE AGREEMENT.
DELETION OF ANY INFORMATION IN THIS HEADER IS IN VIOLATION OF YOUR LICENSE.
Copyright (C) 1994 to 2001 Numerix Ltd.
Description : Chirp z-Transform routines, for SigLib DSP library.
/* Performing this here will save time in the real time process */
siglib_numerix_SDACfft (pvLr, pvLi, pFFTCoeffs, SIGLIB_NULL_SFIX_PTR, FFTSize, Log2FFTSize); /* Contour coeffs. FFT */
