Chip that routes signals pins?
michcfr
Full Member level 1
Hello,
I am looking for a logic chip that does routing of pins signals like ethernet routers does with rj45 plugs.
The router have to route 8 inputs to 32 outputs (or more). The signal is bidirectional like this:
Y0...Y7 pins
Router
v
Z0...Z32 pins
The routing table Yi <=> Zj is stored in the memory of the router.
Do you know a kind of chip that does this work?
Regards,
Michel
This sounds like a cross-point switch, but I'm not sure a single-chip solution for this exists. However, it would be a simple matter to do this with an FPGA or CPLD.
Thank you Barry. This is exactly what I want!
I am looking for low cost solutions. Which FPGA or CPLD should I choose?
Look at the MACHX02 from Lattice, or CoolRunner from Xilinx.
