Chip on glass LCD interface using s1d15719D
Palavi
Newbie level 3
Newbie level 3
India
hi!
I am facing problem in initialization of LCD.
can anybody tell me the sequence of commands
what problem are facing with LCD commands ?
Im sending the commands as per datasheet....
and trying to turn on display by display on/off command
but nothing is happening on display.
Even im not able to analyse whether display is working or not(means if damaged).
is following sequence of commands is write or not
void init_LCD()
delay();
RES = 0;
delay();
delay();
RES = 1;
delay();
delay();
A0 = 1;
delay();
CS = 1;
delay();
write_command(0xAD); //LCD Bias
write_command(0xA0); //seg direction
write_command(0xC0); //coloumn direction
write_command(0x21); //v0 resisor set
write_command(0x81); //Electronic volume
write_command(0x00); //Electronic volume
write_command(0xE1); //power saver off
write_command(0x2F); //power control set
write_command(0x40); //start line
write_command(0x00); //start line
write_command(0xB0); //page addr
write_command(0x10); //coloumn addr upper bit addr
write_command(0x00); //coloumn addr lower bit addr
write_command(0xAE); //display on
//write_command(0xA5); //display all points on
delay1();
void write_command(unsigned char cmd)
A0 = 0;
CS = 0;
delay();
RD = 1;
WR = 0;
LDATA = cmd;
delay();
WR = 1;
delay();
CS = 1;
A0 = 1;
delay();
Hi
First make sure that interface with LCD controller is working befor you try to make all system works
You can do verification by writing and reading a register in the LCD controller
and by writing and reading from the LCD controller memory
All the best
Bobi
The microcontroller specialist
thank you bobi.....
I have written interfacing module....according to it display should turn on at first...but its not happening..either prob is in interface or hardware prob
