leto
Junior Member level 1
read 12 bits
I need to check the status of 12 events of infrared barriers sensors. This must be in "real time" and all of them can appear at the some time.
Then, I'll fire an alarm if the amount of events is less than a "X" number in a second. What is the better manner to solve it?
note:
the input signal is a 5v pulse and it occurs when somebody cut the beam of each sensor. I'll have 12 sensors and its could interrupt each 10ms aprox. I need to detect each interrupt of each sensor.
Thank you
leto
note:
Thank you
leto
