checking sim900 last byte sent to controller
mohamed.elsabagh
Full Member level 2
Full Member level 2
How a micrcontroller connected ti sim900 would know the end of packet send by the sim900.
For example if i send the AT command AT to sim900 it responses with OK so how would i make my controller know that the byte which contains the 'K' is the last byte from the sim900 module without using software delays???
You can test using the following format
Commands are usually followed by a response that includes.”<CR><LF><response><CR><LF>”
But What if in the response there are several <CR><LF> and i can't know how many of them such as reading a message or reading webserver data
Any command followed by" <CR><LF><response><CR><LF>"
*But remember one thing the command will be echo first.
