Check my SMBus protocol code for MLX90615
member_tdh
Member level 5
mlx90615
Hi everybody!
At the moment, I'm studying the SMBUS protocol. I'm making a project that use IR temperature ( MLX90615 ).
The result that i've receied alway is:
Tobj=382.19C
Tobj=382.19C
Tobj=382.19C
My code can wrong, could anybody help me...!!?
Thanks very very much!!!
This is my code:
"SMBus.h"
#ifndef __SMBUS_INCLUDE__
#define __SMBUS_INCLUDE__
#define     _SDA            7   //PORTD.7
#define     _SCL            6   //PORTD.6
#define     _SDA_OUTPUT     DDRD |= (1<<_SDA);
#define     _SDA_INPUT      DDRD &= ~(1<<_SDA);
#define     _SCL_OUTPUT     DDRD |= (1<<_SCL);
#define     mSDA_IN	        PIND.7
#define     mSDA_HIGH	    PORTD |= (1<<_SDA);
#define     mSDA_LOW        PORTD &= ~(1<<_SDA);
#define     mSCL_HIGH	    PORTD |= (1<<_SCL);
#define     mSCL_LOW        PORTD &=~ (1<<_SCL);
#define     TBUF            5
#define     HIGHLEV	        3
#define     LOWLEV	        1
#define     ACK	            0
#define	    NACK            1
#define     WRITE           0x00    // SMBus WRITE command
#define     READ            0x01    // SMBus READ command
#define     SA		        0x00	// SMBus Slave address
#define     DEFAULT_SA      0x5B	// Factory Default SMBus Slave address (MLX90615)
#define     RAM_Access	    0x00	// RAM access command
#define     RAM_Tobj1	    0x07	// To1 address in the eeprom
#define     EEPROM_Access   0x20	// EEPROM access command
#define     Read_Flags		0xF0
#define     SLEEP_mode		0xFF
extern void MLX90615_init(void);
extern void START_bit(void);
extern void STOP_bit(void);
extern void SendRequest(void);
extern void DummyCommand(BYTE);
extern float CalcTemp(WORD);
extern WORD read_RAM(BYTE slaveADDR, BYTE ADDR);
extern WORD read_EEPROM(BYTE slaveADDR, BYTE ADDR);
extern void Object_Temperature(void);
extern void Ambient_Temperature(void);
extern void TruyenByte(BYTE x);
extern BYTE NhanByte(BYTE ack_nack);
#endif
"SMBus.c"
        _SDA_OUTPUT;            // Set SDA as Output
        _SCL_OUTPUT;            // Set SCL as Output
        mSDA_HIGH;              // bus free
        mSCL_HIGH;
        mSDA_HIGH;		        // Set SDA line
        mSCL_HIGH;		        // Set SCL line
        delay_us(TBUF);	        // Generate bus free time between Stop
                                // and Start condition (Tbuf=4.7us min)
        mSDA_LOW;		        // Clear SDA line
        delay_us(TBUF);	        // Hold time after (Repeated) Start
                                // Condition. After this period, the first clock is generated.
                                // (Thd:sta=4.0us min)
        mSCL_LOW;		        // Clear SCL line
void STOP_bit(void)
        delay_us(TBUF);	        // Wait a few microseconds
        mSCL_LOW;
BYTE  i;
        for(i=0;i<8;i++)
            mSCL_LOW;
            if(x&0x80) mSDA_HIGH;
            else  mSDA_LOW;
            x<<=1;
            mSCL_HIGH;
            delay_us(20);
        _SDA_INPUT;                 //SDA line as Input
        mSDA_LOW;                   //ack tai clock thu 9
        mSCL_LOW;
        mSCL_HIGH;
        if(mSDA_IN & 0x80) printf("MLX90615 writed error...ACK!\n\r");
        mSCL_LOW;
BYTE i;
WORD byte=0;
        _SDA_INPUT;
        mSCL_LOW;
        for(i=0;i<8;i++)
            byte<<=1;
            mSCL_HIGH;
            byte|=mSDA_IN;
            mSCL_LOW;
            delay_us(20);
        _SDA_OUTPUT;                              //DATA-line in output
        PORTD.7=!ack_nack;                          //"ack==1" pull down DATA-Line
        mSCL_HIGH;
        delay_us(20);
        mSCL_LOW;
        //_SDA_INPUT;                            //DATA-line in input
        //mSDA_HIGH;
        return byte;
BYTE data_4lsb;
BYTE data_4msb;
BYTE data_crc;
WORD data;
        START_bit();
        TruyenByte(slaveADDR);
        TruyenByte(ADDR|RAM_Access);
        START_bit();
        TruyenByte(slaveADDR|0x01);
        data_4lsb = NhanByte(ACK);
        data_4msb = NhanByte(ACK);
        data_crc  = NhanByte(ACK);
        STOP_bit();
        data=(WORD)data_4msb<<8|data_4lsb;
        return data;
"main.c"
This program was produced by the
CodeWizardAVR V1.24.8d Professional
Automatic Program Generator
© Copyright 1998-2006 Pavel Haiduc, HP InfoTech s.r.l.
[url]http://www.hpinfotech.com[/url]
Project :
Version :
Date    : 7/20/2009
Author  : F4CG
Company : F4CG
Comments:
Chip type           : ATmega32
Program type        : Application
Clock frequency     : 8.000000 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 512
#include "mega32.h"
#include "global.h"
#include "SMBus.c"
void main(void)
delay_ms(100);      //Power Startup Stable
PORTA=0x00;
DDRA=0xFF;
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0xFF;
PORTD=0x00;
DDRD=0xFE;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud rate: 9600
UCSRA=0x00;
UCSRB=0x98;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x33;
// Global enable interrupts
//#asm("sei")
printf(" --------------------------------------- \n\r");
printf(" ------------ IR TEMPERATUR ------------ \n\r");
printf(" ------------    MLX90615   ------------ \n\r");
MLX90615_init();
delay_ms(200);		                //Wait after POR,Tvalid=0.15s
    while (1)
            Object_Temperature();
            delay_ms(1000);
    };//end while
}//end main
WORD temperature;
        temperature = read_RAM(0x00, 0x07);
        printf("Tobj=%d.%dßC \n\r", ((temperature*2)-27315)/100, ((WORD)((temperature*2)-27315))%100);
mlx90615 smbus
what the heck is SMBus ?? Post some details about this
    member_tdh
smbus ack
Hi!
SMBus (sensor MLX90615) similar I2C but difference the fomat data.
You can find the doccuments on : www.melexis.com
and help me...pls!?
mlx90615
Have you resolved this yet?
I think that your command bytes for RAM and EEPROM are wrong. From the table in section 8.4.6 of the datasheet I think they should be:
#define RAM_Access 0x20 // RAM access command
#define EEPROM_Access 0x10 // EEPROM access command
However, i must admit that I've not got it to work either yet... If anyone has any example code that is working please help us out.
smbus+mlx90615
Hurray!! - It is now working properly with the RAM address that I quoted above (having enabled PIC option for SMBus compatible voltage levels). Getting the CRC code to generate the correct values for the PEC byte took a bit of effort but all OK. If anyone else is still struggling with this please let me know as I'm happy to share code/experience.
Re: SMBus with MLX90615
Hello ,
I am also doing IR sensor MLX90615 using with PIC16F.
Now i am facing the problem. The result is always same when reading several times. I used the assembly language.
Please help to me!
Thanks
I am facing the same problem with PIC32 board. Would you send the properly working code to wzxfn_116@hotmail.com. Thank you very much
SMBus with MLX90615
i use 89c4051 to control MLX90615, but i only received low data byte, the high, REC data was disappear in my Logic Analyzers. some one could help me!
SMBus with MLX90615
Hi,I am using the sensor for a project as well.I am however using i2c.I am yet to get it working though.Have you any success with this sensor?
I made sensor's array with MLX90615 controlled with PIC18F13K50, with no additional parts like switches, MUX, etc... Work perfect. PEC control not requires with correct layout design. In the first version used table based PEC. The final version doesn’t implement PEC. My design support up to 24 MLX90615 devices simultaneously with no address changes (5Bh factory address used).
Read/Write SMB clock about 30 KHz (read) 35 KHz (write) with 16 MHz internal PIC18F13K50 oscillator.
