Cheap RGB laser project
gres
Full Member level 4
Full Member level 4
Cheap RGB laser
I would like to present project of cheap RGP laser. The idea of project is to use three different colors lasers ( red, green , blue) which common laser bundle. Thanks to right steering we can get colour that we wont. Red laser I get from DVD recorder, green from standard laser pointer, and violet one HD DVD reader. Wave range is 650 for red, 532 for green and 405nm for violet. Although 405nm is violet not blue as it should be, but it still work corectly. Unfortunately blue one with right wave range 473nm is very expensive. If you really need clear blue you can turn on 405nm and low power 532nm at the same time. Thanks to low power of green you don't have to worry about getting cyan.
Lasers diode's from DVD and HD DVD are placed in collimators that are using in standard laser pointers with low power. To merge all 3 bundles I used two interference filters - I got them from the same pointers. All optic I placed on aluminum box. All construction goes to box made with aluminum and wood elements.
All that you need is:
- DVD recorder ( could be damaged)
- HD DVD reader e.g. from Xbox 360
- collimators came from laser pointers
- green laser pointer
- plate for laser diode driver
- few piece of aluminum and wood
- bookbinding glue
Not much! Maybe the power is not amazing, but you still can have VERY CHEAP RGB laser, besides - great satisfaction!
Text came from https://www.elektroda.pl/rtvforum/topic1443541.html
Cheap RGB laser
kindly share control circiut for the above project
thanks
br
hobbiest_2k3
Cheap RGB laser
Did anyone try to use white-black way(either red, green or blue) for full frame scan of 320x 240 points (QVGA)?
