ozgur85
Member level 1
Hello everyone :smile:
I have Sanyo 103450AR 3.7V 1880mAh lithium ion batteries. They have control circuits. (protected)
I want to use Powerplus adapter (mobile phone charger) (4.3-7V 500mA, 100-240V) to charge them. (I added a picture of it)
I also added the voltage values when battery is not charging and when it's charging. When the battery voltage is 4.20, the adapter automatically stops charging. When the current is about be cut off (while charging), the voltage value i measure is 4.26-4.30V. I unplug the adapter, measure the battery voltage and it's 4.20.
When the adapter is in idle, the voltage is 6.13V.
The battery is full after 4,5 hours of charging. After the battery is charged, i look at the voltage and it's 4.20V and it doesn't drop quickly. Also the battery is always cool.
So, the question is, can we say charging these batteries with this adapter (not an expensive charger) is OK and the charging could efficient enough? Actually i am happy with the run time but one person said the charge is not going long enough. But he could be wrong.
Your helps are much appreciated :smile:
Thank you
Thank you
