steinar96
Member level 5
I was wondering if during the CC phase they raised the voltage of the lithium cells above 4.2V to keep the current constant. Or is 4.2V the absolute maximum voltage across them. Info on this is very vaque.
---------- Post added at 16:19 ---------- Previous post was at 15:59 ----------
I suspect that during the CC they put whatever voltage is required to get the current sought after since the cells clamp the output voltage anyway to the sum of their internal voltages so in effect the voltage across them is never higher then 4.2V unless they have started charging beyond specifications.
