Waqas_MicroSolutions
Member level 1
hi..
can any one explain how can I increase the charging current for 7.2Volts/2800mAH NiCd battery..??
I have tried many circuits like..
http://www.reuk.co.uk/print.php?article=LM317-High-Current-Voltage-Regulator.htm
NiCd Battery Charger - Fig3
etc...
They look good but in fact they are useless for me because when Battery is connected the charging current is reduced significantly to about 290 to 300mA... which is too low..
I'm using simple transformer supply (3A/12V) with full wave bridge rectifier+1000 µF Polar Capacitor...
when I charged the battery without any current/voltage regulator circuit i.e., direct from the rectifier's O/P(in parallel with the capacitor) the charging current was initial 1.3A and after about 30 minutes it was 0.8A..
Is there any method (circuit) that can draw even more current from that transformer supply....
I need 1.5A to 2A charging current at least( better be controlled as I have to use it with µController)..
Exerts out there, plz help me cause I'm already late..
etc...
