juxtapose1988
Newbie level 2
Hello all,
I had some general questions about a project I'm working on for a senior design class.
I found a schematic for a battery charging circuit and modified it somewhat to fit my purposes.
First, I wanted to run this by someone to make sure it makes sense.
In essence, a solar panel will act as an input and be split to 2 LM317s for voltage regulation. On the left, the voltage will power the laser while the panel receives sun, whereas the right regulator will act as a power source to charge a battery.
When the panel is gone, the battery will discharge through the laser to make it operate beyond what the panel alone can do.
First, our design specs call for the battery to charge in about 4 hours while we obtain sun. Is this even possible?
Second, the battery we chose is a rechargeable 9V Duracell. I believe I can modify this by just tweaking the outputs of the regulators if need be.
However, a problem I've faced is that after allowing the battery to discharge (in order to obtain an idea of operational lifetime), it does not charge. I can attach it to my circuit and not read any appreciable change in voltage.
Furthermore, when attaching the battery to a meter, the voltage constantly increases, so I can never be sure what the actual voltage is. I believe the meter is somehow charging the battery, but I'm not sure...
At this point, I'd appreciate any suggestions, ideas, critiques, or anything else you can let me know. I left out a lot of information, so also feel free to ask for anything else you need to know.
Thanks.
Thanks.
