Charge pump regulator, when Vin is larger tha Vout ?
ahgu
Full Member level 3
Full Member level 3
charge pump regulator
REG71055
it says input range is 1.8v to 5.5v for Vout=5.5v
I wonder what if the input is larger than 5.5v? will that still work for charge pump regulator? What will be the characteristics for chage pump regulator when vin is larger than Vout?
thanks
ahgu
Re: charge pump regulator
it can work.
use pmos as switch.
if vin>vout, it work as a regulator in linear mode
I have to put a pmos? or it is already in there?
Hi
I find some CMOS charge_pump usually use Vin=2.7~5 Vo=5.5v
Io=100ma .. why have 2.7v limit ??
and if I want to design 1.2v -> 5.5v Io=100ma , how large size pmos
switch will be use ? (assume cmos 5v 0.5um process )
someone tell me pmos need large reduce Rds_on ..
but I use (20/0.5 )* 20 cmos switch
I find Vo have limit when vin=2.5 vo=4.4 not 5v
