changing the multiplier of a transistor in Virtuoso Schem.
buru
Junior Member level 1
Cadence IC
Does anyone know how to change the "multiplier" of a transistor in Virtuoso Schematic Editor (Cadence IC5033)
Cadence IC
Select the transistor and then push the q key, you will find the option.
Cadence IC
multiplier need to be defined first then could be change as a property value of instance
Re: Cadence IC
Thank you very much!
Now i found out that multipier can be set also in the instance name:
inst_name<0:n> where n is any natural number
