Changing Net colour for selected nets in allegro!
binu G
Advanced Member level 2
Bangalore
hi ,
i there a way where i can define the net color for selected nets in allegro ?
like what we can do in powerpcb
binu g
Yes. Select the Highlight Icon. Then in the right tool options field select a color. Then you will have to select a net. The net will be permanently highlighted until you decide to dehighligt the nets. Thus you can go through all nets and assign different colors to them. Traces will be candy-striped, but shapes (planes) will be solid colored which can fool you since the highlight color overrides the color which you have chosen in the color setup panel.
    binu G
But its not that visible like in powerpcb
You should check display_nohilitefont of Display at user preferenece to view the highlites effectively.
"But its not that visible like in powerpcb "
This is a problem in Allegro and Cadence people are promising to fix this in upcoming releases.
Majnoon
I think it's just as visible as Pads - the color saturation and brightness is slghtly subdued, I think the problem is it has a limited color selection with several colors very similar to other hues, if you view a negative plane with a net that has been highlighted it will not display correctly - no thermals and clearances disappear.
SiGiNT
You should select Display->Color, then in the pop up Group, select Display then select color for Temporary highlight
That's all.
NgonBui.
