lctlcm
Junior Member level 3
font error in IC*5.0
Hi all,
I had a problem in IC5, running on RedHat8, Please help.
After i transfer/copied the cadence's library files from solaris to linux, some of the cell view in the library has change the font from big-init-cap to small-cap letters. (Not all the cellview is change and also not all libraries are affected.) This causes the major link error issue as it state that the specific cell cannot be found......
Anyone also has this issue and was solved?
Is this due to the warning message of
>>Cannot convert string "-abode-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type FontStruct. <<
Thanks in advance.
Regards.
Hi all,
Thanks in advance.
Regards.
