[SOLVED] Change from Hyper light load mode to forced PWM mode
FreshmanNewbie
Advanced Member level 1
In this IC - Converter, Is there a possibilty/workaround to deactivate it? Or decreace the threshold of the current needed to activate Forced PWM mode?
Trying to understand.
Reading the data sheet, it doesn't look like there's any way around it. If you didn't want that function, why did you design it in? There are other regulators that allow you to enable that function.
