CF Card reader/writer interface USB.
pamnul
Newbie level 6
Newbie level 6
cf card reader writer
I want to design a CF Card Reader/Writer interface USB using PDIUSBD12. I don't know how to write program run in Window 98/2k to detect my circuit and see it as Removeable Disk.
Best regards!
Did you consider using a dedicated solution ? (for example the ISD-300LP from Cypress). It will give you the full transfer speed, which is very important. For example, I'm very dissapointed after trying to implement a SmartMedia card writer on USB using the FT245BM device from FTDI, because I can't get enough speed, even though the protocol is working fine.
If you still want to use PDIUSBD12, check this link:
hxxp://www.semiconductors.philips.com/buses/usb/products/device/pdiusbd12/mp3_eval/
It should give you some pointers.
Thanks for your reply, I have found a chip for CF reader, It is C236 of OnSpec, This IC support to CF Card connect to PC using USB interface, it's very easy for user, but I don't have datasheet of it. If anybody have it, please send to me.
thanks
